주요 콘텐츠로 건너뛰기
Ambient Weather WS-1001-Wifi Battery Replacement
필요한 것
  1. Ambient Weather WS-1001-Wifi Battery Replacement, Battery: 1 단계, 이미지 1/2 Ambient Weather WS-1001-Wifi Battery Replacement, Battery: 1 단계, 이미지 2/2
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a plastic opening tool.
  2. Ambient Weather WS-1001-Wifi Battery Replacement: 2 단계, 이미지 1/1
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
  3. Ambient Weather WS-1001-Wifi Battery Replacement: 3 단계, 이미지 1/2 Ambient Weather WS-1001-Wifi Battery Replacement: 3 단계, 이미지 2/2
    • Remove the 4 M2x1.5-7 screws (7mm length) from the green PCB board.
    • This will result in two pieces, the back black cover and the PCB board.
  4. Ambient Weather WS-1001-Wifi Battery Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • The battery can then be popped out using precision tweezers and replaced with a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Taylor Whitaker
회원 가입일: 11/06/17
122 평판
안내서 1개 작성함
IUPUI, Team S1-G2, Harley Fall 2017 IUPUI, Team S1-G2, Harley Fall 2017 회원
IUPUI-HARLEY-F17S1G2
4 회원들
안내서 3개 작성하였습니다
댓글 한 개
Hello. My screen is not working. And the electric cable is good.
C Kaagman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 783
