주요 콘텐츠로 건너뛰기
Ambient Weather WS-1001-Wifi LCD Screen Replacement
필요한 것
  1. Ambient Weather WS-1001-Wifi LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/1
    • First, you will need to remove all four M2x1-7 screws (7mm length) located on the back of the device. This should be done using a Phillips #1 screw driver.
  2. Ambient Weather WS-1001-Wifi LCD Screen Replacement: 2 단계, 이미지 1/1
    • From the side of the device use the plastic opening tool to pry the gray front casing from the rear black casing.
    • The ribbon cable is attached inside so the two pieces will not come completely apart. See step 3.
  3. Ambient Weather WS-1001-Wifi LCD Screen Replacement: 3 단계, 이미지 1/1
    • Using a plastic opening tool, carefully press the black bar towards the ribbon and away from the white bar in order to release it.
    • The ribbon cable should come out and be attached to the back of the LCD screen resulting in two separate pieces.
  4. Ambient Weather WS-1001-Wifi LCD Screen Replacement: 4 단계, 이미지 1/2 Ambient Weather WS-1001-Wifi LCD Screen Replacement: 4 단계, 이미지 2/2
    • Next, you need to remove the LCD screen from the front casing.
    • Push on the front of the LCD screen to pop it out as seen in picture 2.
결론
Jeremiah Miskimen
회원 가입일: 11/06/17
107 평판
안내서 1개 작성함
IUPUI, Team S1-G2, Harley Fall 2017 IUPUI, Team S1-G2, Harley Fall 2017 회원
IUPUI-HARLEY-F17S1G2
4 회원들
안내서 3개 작성하였습니다
댓글 2개
Pretty useless guide since this is all pretty self explanatory with no reference on where to get a replacement or even a part number
Jared Dykstra - 답글
Exactly right.
j drag -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 364
