주요 콘텐츠로 건너뛰기
소개
Use this guide to remove or replace a driver pad on a Clarke Floor Sander 07163A 2012.
This guide shows the removal of just one pad, but the procedure for the other two pads is identical.
도구
  1. Before you begin, be sure that the sander is unplugged and powered off.
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
  2. Peel the hook-and-loop sandpaper disc off of the driver assembly.
    • Peel the hook-and-loop sandpaper disc off of the driver assembly.
  3. Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad. Remove the driver pad from the sanding disc.
    • Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
    • Remove the driver pad from the sanding disc.
결론
Miles Robinson
회원 가입일: 2019년 03월 04일
839 평판
안내서 7개 작성하였습니다
The Home Depot The Home Depot 회원
Community
7,046 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 107
