주요 콘텐츠로 건너뛰기
소개
Use this guide to remove or replace the interlock assembly in a Clarke Floor Sander 07163A 2012.
도구
  1. Before you begin, make sure the sander is turned off and unplugged.
    • Before you begin, make sure the sander is turned off and unplugged.
    • Use a 3/16" hex key or driver bit to remove the six 23.4 mm-long screws holding the two halves of the handle enclosure together.
  2. The rear half of the enclosure is bolted to the handle support, so the front half will be removed first. Pull the front half of the enclosure straight away from the rear half to separate the enclosure. If the interlock assembly comes out with the front half of the enclosure, detach it and place it back into the rear half.
    • The rear half of the enclosure is bolted to the handle support, so the front half will be removed first.
    • Pull the front half of the enclosure straight away from the rear half to separate the enclosure.
    • If the interlock assembly comes out with the front half of the enclosure, detach it and place it back into the rear half.
    • Remove the front half of the handle enclosure.
  3. Pull the wires connected to the interlock assembly straight out of their connectors. Keep track of where each wire connects on the interlock assembly. Keep track of where each wire connects on the interlock assembly.
    • Pull the wires connected to the interlock assembly straight out of their connectors.
    • Keep track of where each wire connects on the interlock assembly.
  4. After all wires are disconnected from the interlock assembly, remove the interlock assembly from the handle.
    • After all wires are disconnected from the interlock assembly, remove the interlock assembly from the handle.
결론
Miles Robinson
회원 가입일: 2019년 03월 04일
839 평판
안내서 7개 작성하였습니다
The Home Depot The Home Depot 회원
Community
7,046 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 35
