주요 콘텐츠로 건너뛰기
American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement
필요한 것
  1. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sandpaper disc: 1 단계, 이미지 1/1
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
  2. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: 2 단계, 이미지 1/1
    • Peel the hook-and-loop sandpaper disc off of the driver assembly.
  3. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the driver pad: 3 단계, 이미지 1/2 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the driver pad: 3 단계, 이미지 2/2
    • Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
    • Remove the driver pad from the sanding disc.
  4. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sanding disc: 4 단계, 이미지 1/3 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sanding disc: 4 단계, 이미지 2/3 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sanding disc: 4 단계, 이미지 3/3
    • Use a flathead screwdriver to pry off and remove the rubber plug in the center of the sanding disc.
  5. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: 5 단계, 이미지 1/2 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: 5 단계, 이미지 2/2
    • Slide a thin 22 mm wrench underneath the sanding disc and clasp it onto the flat part of the motor driveshaft to keep the driveshaft from turning.
  6. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: 6 단계, 이미지 1/2 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: 6 단계, 이미지 2/2
    • Use an 11 mm socket and socket wrench to remove the 16.5 mm-long bolt securing the sanding disc to the motor driveshaft.
    • Apply counter torque to the driveshaft wrench as you loosen the bolt to keep the sanding disc from spinning.
  7. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: 7 단계, 이미지 1/3 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: 7 단계, 이미지 2/3 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: 7 단계, 이미지 3/3
    • Take two pry bars and insert them underneath the sanding disc as close to the driveshaft as possible.
    • Apply pressure to the pry bars in opposite directions to carefully pry the sanding disc off of the driveshaft.
    • Remove the sanding disc from the floor sander.
  8. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sanding disc bearing: 8 단계, 이미지 1/3 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sanding disc bearing: 8 단계, 이미지 2/3 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sanding disc bearing: 8 단계, 이미지 3/3
    • Use a pair of snap ring pliers to compress the retaining ring inside the driver and remove it from the sanding disc.
    • It may help to use a small flathead screwdriver to pry out the retaining ring as you remove it.
  9. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: 9 단계, 이미지 1/3 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: 9 단계, 이미지 2/3 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: 9 단계, 이미지 3/3
    • Place a 15/16" socket inside the center of the sanding disc and use a mallet to tap the bearing out of the disc.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Craig Lloyd
회원 가입일: 02/10/16
35,418 평판
안내서 82개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 13
30일 전: 48
전체 시간: 1,813
