주요 콘텐츠로 건너뛰기
Analogue Pocket Right Speaker Replacement
필요한 것
  1. Analogue Pocket Right Speaker Replacement, Prepare your device for disassembly: 1 단계, 이미지 3개 중 1개 Analogue Pocket Right Speaker Replacement, Prepare your device for disassembly: 1 단계, 이미지 3개 중 2개 Analogue Pocket Right Speaker Replacement, Prepare your device for disassembly: 1 단계, 이미지 3개 중 3개
    • Unplug all cables and fully power off your device.
    • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
  2. Analogue Pocket Right Speaker Replacement, Unfasten the battery shell: 2 단계, 이미지 2개 중 1개 Analogue Pocket Right Speaker Replacement, Unfasten the battery shell: 2 단계, 이미지 2개 중 2개
    • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
  3. Analogue Pocket Right Speaker Replacement, Remove the battery shell: 3 단계, 이미지 3개 중 1개 Analogue Pocket Right Speaker Replacement, Remove the battery shell: 3 단계, 이미지 3개 중 2개 Analogue Pocket Right Speaker Replacement, Remove the battery shell: 3 단계, 이미지 3개 중 3개
  4. Analogue Pocket Right Speaker Replacement, Disconnect the battery: 4 단계, 이미지 2개 중 1개 Analogue Pocket Right Speaker Replacement, Disconnect the battery: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
    • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
  5. Analogue Pocket Right Speaker Replacement, Remove the battery: 5 단계, 이미지 3개 중 1개 Analogue Pocket Right Speaker Replacement, Remove the battery: 5 단계, 이미지 3개 중 2개 Analogue Pocket Right Speaker Replacement, Remove the battery: 5 단계, 이미지 3개 중 3개
    • Lift one of the battery's short edges until the clips release.
    • Remove the battery.
    • During reassembly, push the battery into its recess until the clips engage.
  6. Analogue Pocket Right Speaker Replacement, Unclip the button board: 6 단계, 이미지 3개 중 1개 Analogue Pocket Right Speaker Replacement, Unclip the button board: 6 단계, 이미지 3개 중 2개 Analogue Pocket Right Speaker Replacement, Unclip the button board: 6 단계, 이미지 3개 중 3개
    • A plastic clip secures the center of the button board.
    • Use the point of a spudger to push the clip out and release the board.
    • Don't try to remove the board—a delicate ribbon cable secures it to the device.
  7. Analogue Pocket Right Speaker Replacement, Reposition the button board: 7 단계, 이미지 3개 중 1개 Analogue Pocket Right Speaker Replacement, Reposition the button board: 7 단계, 이미지 3개 중 2개 Analogue Pocket Right Speaker Replacement, Reposition the button board: 7 단계, 이미지 3개 중 3개
    • Swing the bottom edge of the button board up and over the cartridge reader.
    • Set the board on top of the cartridge reader so the cable's connector is facing the bottom of the device.
    • During reassembly:
    • Put the top edges of the board under their tabs on the rear shell.
    • Lay the board onto the rear shell so the alignment posts go into their circular cutouts on the board.
    • Press the board down until the plastic clip engages.
  8. Analogue Pocket Right Speaker Replacement, Disconnect the button board: 8 단계, 이미지 3개 중 1개 Analogue Pocket Right Speaker Replacement, Disconnect the button board: 8 단계, 이미지 3개 중 2개 Analogue Pocket Right Speaker Replacement, Disconnect the button board: 8 단계, 이미지 3개 중 3개
    • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the board cable ZIF connector located on the board itself.
    • Use blunt nose tweezers to pull the cable straight out of its socket.
  9. Analogue Pocket Right Speaker Replacement, Remove the board: 9 단계, 이미지 2개 중 1개 Analogue Pocket Right Speaker Replacement, Remove the board: 9 단계, 이미지 2개 중 2개
    • Remove the board.
  10. Analogue Pocket Right Speaker Replacement, Unclip the rear shell: 10 단계, 이미지 3개 중 1개 Analogue Pocket Right Speaker Replacement, Unclip the rear shell: 10 단계, 이미지 3개 중 2개 Analogue Pocket Right Speaker Replacement, Unclip the rear shell: 10 단계, 이미지 3개 중 3개
    • Sliding tabs secure the perimeter of the rear shell.
    • Firmly grip your device with one hand.
    • With your free hand, lift the bottom edge of the rear shell until it clears the front shell.
    • Pull the rear shell down until the sliding tabs disengage.
  11. Analogue Pocket Right Speaker Replacement, Remove the rear shell: 11 단계, 이미지 3개 중 1개 Analogue Pocket Right Speaker Replacement, Remove the rear shell: 11 단계, 이미지 3개 중 2개 Analogue Pocket Right Speaker Replacement, Remove the rear shell: 11 단계, 이미지 3개 중 3개
    • Remove the rear shell.
    • Thread the button board cable through its slot in the rear shell.
    • Lay the rear shell on the front shell so its bottom edge slightly overhangs.
    • This allows the tabs to slide into place. If the rear shell is perfectly flush with the front shell, the tabs won't slide.
    • Push the rear shell in and slide it up to engage the sliding tabs.
  12. Analogue Pocket Right Speaker Replacement, Disconnect the speaker: 12 단계, 이미지 3개 중 1개 Analogue Pocket Right Speaker Replacement, Disconnect the speaker: 12 단계, 이미지 3개 중 2개 Analogue Pocket Right Speaker Replacement, Disconnect the speaker: 12 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • The right speaker will be on your left-hand side, as the device is laying upside down.
    • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the right speaker cable ZIF connector.
  13. Analogue Pocket Right Speaker Replacement, Unfasten the speaker: 13 단계, 이미지 2개 중 1개 Analogue Pocket Right Speaker Replacement, Unfasten the speaker: 13 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the two 4.7 mm‑long screws securing the right speaker.
  14. Analogue Pocket Right Speaker Replacement, Remove the speaker: 14 단계, 이미지 3개 중 1개 Analogue Pocket Right Speaker Replacement, Remove the speaker: 14 단계, 이미지 3개 중 2개 Analogue Pocket Right Speaker Replacement, Remove the speaker: 14 단계, 이미지 3개 중 3개
    • Insert the point of a spudger between the bottom left corner of the speaker and the front shell.
    • Pry up the speaker and remove it.
결론
작성자
2다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
149,525 평판
안내서 995개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,623개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 26
전체 시간: 536
