소개
This repair guide will show you how to replace the top blade on your Andis T Outliner Trimmer with T Blade Model G.
A dull blade is the best indicator that you need to replace the blade. If your razor pulls your hairs or begins to feel rough on your skin, it’s likely time for a replacement.
The five-step process is easy. Each of the steps is accompanied by a brief description and photos demonstrating what you will need to do.
Note: The blade is sharp so use caution when handling it.
필요한 것
Turn the control on the trimmers to "off".
Remove the plug from the electrical outlet.
Remove the two blade screws from the top blade of the trimmer.
Lift the top blade from the device.
The bottom blade is attached, but not secured, to the underside of the top blade.
Flip the top blade over.
Lift the bottom blade from the top blade.
다른 3명이 해당 안내서를 완성하였습니다.
