주요 콘텐츠로 건너뛰기
Andobil Easy Clip Car Mount Replacement
필요한 것
  1. Andobil Easy Clip Car Mount Replacement, Car Mounting Clip: 1 단계, 이미지 1/1
    • In this case, the plastic connecting to the metal spring failed and caused one of the clip arms to break off.
    • Be sure to remove any pieces of broken plastic before you begin the fix.
  2. Andobil Easy Clip Car Mount Replacement: 2 단계, 이미지 1/1
    • Loosen the knob on the back of the phone holder.
    • Be sure to hold on to this knob as it will be integral to the rest of the fix.
  3. Andobil Easy Clip Car Mount Replacement: 3 단계, 이미지 1/2 Andobil Easy Clip Car Mount Replacement: 3 단계, 이미지 2/2
    • Once the knob is fully removed, the inside ball joint loosens up and can be moved around.
    • Remove the ball joint from the base of the phone holder.
  4. Andobil Easy Clip Car Mount Replacement: 4 단계, 이미지 1/1
    • Remove the tightening knob and set the broken clip aside or toss it in the trash.
  5. Andobil Easy Clip Car Mount Replacement: 5 단계, 이미지 1/2 Andobil Easy Clip Car Mount Replacement: 5 단계, 이미지 2/2
    • Locate the replacement clip that comes with the Andobil Easy Clip Car Mount Kit.
    • Put Tightening Knob on top of the new ball-jointed clip.
  6. Andobil Easy Clip Car Mount Replacement: 6 단계, 이미지 1/1
    • Insert the new clipping mechanism into the back of the phone holder.
  7. Andobil Easy Clip Car Mount Replacement: 7 단계, 이미지 1/1
    • Open the Jaws using the knob on the top of the ball joint mechanism.
  8. Andobil Easy Clip Car Mount Replacement: 8 단계, 이미지 1/1
    • Line up the jaws with the car vent and then use the knob on the bottom to close the jaws.
  9. Andobil Easy Clip Car Mount Replacement: 9 단계, 이미지 1/1
    • Tighten the knob on the back of the phone holder once you have adjusted it to the correct angle.
  10. Andobil Easy Clip Car Mount Replacement: 10 단계, 이미지 1/1
    • Once you've finished tightening the knob, you are finished! This is the finished Product!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alexander Tavares
회원 가입일: 03/24/21
205 평판
안내서 1개 작성함
UMass Dartmouth, Team S2-G16, Riel Spring 2021 UMass Dartmouth, Team S2-G16, Riel Spring 2021 회원
UMASSD-RIEL-S21S2G16
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 12
30일 전: 80
전체 시간: 1,741
