주요 콘텐츠로 건너뛰기
Andoer HDV 107 Strap Replacement
필요한 것
  1. Andoer HDV 107 Strap Replacement, Strap: 1 단계, 이미지 1/1
    • At the bottom of the camera you will see the battery compartment cover as seen in the picture
    • To open this compartment, apply pressure in the direction of the arrow and remove.
  2. Andoer HDV 107 Strap Replacement: 2 단계, 이미지 1/1
    • Remove the 1 mm circled screws with the Phillips head #000 screwdriver.
  3. Andoer HDV 107 Strap Replacement: 3 단계, 이미지 1/1
    • Remove the 1 mm Phillips head screw.
  4. Andoer HDV 107 Strap Replacement: 4 단계, 이미지 1/1
    • Once all previous screws have been removed the panel can be pulled off of the camera.
  5. Andoer HDV 107 Strap Replacement: 5 단계, 이미지 1/1
    • Use your screwdriver to remove the 1 mm Phillips head screw and release the strap.
결론
Isaac Saron
회원 가입일: 03/20/17
516 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G4, Isaacson Spring 2017 UMass Dartmouth, Team S2-G4, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 155
