주요 콘텐츠로 건너뛰기
Nobis NB09 Battery Replacement
필요한 것
  1. Nobis NB09 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Before beginning this process, make sure the device is powered off.
    • Remove the screws holding the case together.
  2. Nobis NB09 Battery Replacement: 2 단계, 이미지 1/3 Nobis NB09 Battery Replacement: 2 단계, 이미지 2/3 Nobis NB09 Battery Replacement: 2 단계, 이미지 3/3
    • Use an opening tool to loosen and pry off the pink back plate.
  3. Nobis NB09 Battery Replacement: 3 단계, 이미지 1/2 Nobis NB09 Battery Replacement: 3 단계, 이미지 2/2
    • Remove the black electronic tape covering the circuit board.
  4. Nobis NB09 Battery Replacement: 4 단계, 이미지 1/1
    • Use the soldering iron to remove the black and red wires from the circuit board.
    • The black wire is the ground and the red wire is the battery positive terminal.
    • To reassemble, use the soldering iron to solder the leads at the end of the black (-) and red (+) wires from the new battery onto the proper terminals on the circuit board.
  5. Nobis NB09 Battery Replacement: 5 단계, 이미지 1/2 Nobis NB09 Battery Replacement: 5 단계, 이미지 2/2
    • Gently loosen the adhesive under the battery to avoid damaging it.
    • Use caution; the battery is soft and will bend very easily.
    • Dispose of the old battery properly at an electronic waste center or verified battery recycling store.
    • When reassembling, apply adhesive to the back of the new battery.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jackson McAdams
회원 가입일: 04/01/15
390 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 7-1, Cichon Spring 2015 UMass Dartmouth, Team 7-1, Cichon Spring 2015 회원
UMASSD-CICHON-S15S7G1
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
where can i buy a battery from
Frederick Shipman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 13
전체 시간: 2,956
