주요 콘텐츠로 건너뛰기
Android tablet Nobis NB09 Camera Replacement
필요한 것
  1. Android tablet Nobis NB09 Camera Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Remove the two 00 Phillips screws located in the right hand side of the tablet.
  2. Android tablet Nobis NB09 Camera Replacement: 2 단계, 이미지 3개 중 1개 Android tablet Nobis NB09 Camera Replacement: 2 단계, 이미지 3개 중 2개 Android tablet Nobis NB09 Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Use plastic opening tools to loosen and pry off the back plate (pink piece).
    • When removing the cover, be careful not to pull too hard as there are wires connected to the motherboard attached to the back cover.
  3. Android tablet Nobis NB09 Camera Replacement, Camera: 3 단계, 이미지 2개 중 1개 Android tablet Nobis NB09 Camera Replacement, Camera: 3 단계, 이미지 2개 중 2개
    • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge)
    • Start by removing the electrical tape covering the camera, located at the top left corner of the device.
    • Remove enough tape to expose the ZIF connector and the camera.
  4. Android tablet Nobis NB09 Camera Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Lift up the black plastic lock on the ZIF connector with tweezers.
    • ZIF stands for Zero Insertion Force connector. Make sure the connector is unlocked completely.
  5. Android tablet Nobis NB09 Camera Replacement: 5 단계, 이미지 2개 중 1개 Android tablet Nobis NB09 Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Gently remove the camera by removing the power cord with tweezers. The camera should release easily: do not twist or pull too hard.
    • Replace the camera with a new one.
결론
To reassemble your device, follow these instructions in reverse order. Do not forget to put electrical tape back in place.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Sergey Kasyanov
회원 가입일: 03/26/15
237 평판
안내서 2개를 작성함
UMass Dartmouth, Team 7-1, Cichon Spring 2015 UMass Dartmouth, Team 7-1, Cichon Spring 2015 회원
UMASSD-CICHON-S15S7G1
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 268
