주요 콘텐츠로 건너뛰기
Android tablet Nobis NB09 Screen Replacement
필요한 것
  1. Android tablet Nobis NB09 Screen Replacement, Screen: 1 단계, 이미지 1/3 Android tablet Nobis NB09 Screen Replacement, Screen: 1 단계, 이미지 2/3 Android tablet Nobis NB09 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Remove the two 00 Phillips screws located on the right side of the tablet.
    • Use the plastic opening tools to loosen and then pry the back if the tablet off.
    • When prying off the back of the tablet, be careful around the tablets ports. Too much pressure can cause cracks.
  2. Android tablet Nobis NB09 Screen Replacement: 2 단계, 이미지 1/3 Android tablet Nobis NB09 Screen Replacement: 2 단계, 이미지 2/3 Android tablet Nobis NB09 Screen Replacement: 2 단계, 이미지 3/3
    • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge)
    • Remove the electrical tape covering the motherboard.
    • Remove the four 4.0 mm T4 Torx screws holding the motherboard to the front half of the tablet.
    • Remove any remaining adhesive tape on the exposed area.
    • Disconnect the ribbon cable attachments by lightly pushing up the locking arm (black tab) on each then gently detaching the pin connectors.
  3. Android tablet Nobis NB09 Screen Replacement: 3 단계, 이미지 1/3 Android tablet Nobis NB09 Screen Replacement: 3 단계, 이미지 2/3 Android tablet Nobis NB09 Screen Replacement: 3 단계, 이미지 3/3
    • Find the notch on the digitzer, located on the left side of the device.
    • Use the Phillips Screwdriver to gently push the notch and lift the digitizer from the screen.
  4. Android tablet Nobis NB09 Screen Replacement: 4 단계, 이미지 1/3 Android tablet Nobis NB09 Screen Replacement: 4 단계, 이미지 2/3 Android tablet Nobis NB09 Screen Replacement: 4 단계, 이미지 3/3
    • Gently slide the digitizer from its clasps to remove it from the screen.
    • The digitizer should now be removed separately from the screen.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Enea Osmann
회원 가입일: 10/31/14
158 평판
안내서 1개 작성함
UMass Dartmouth, Team 7-1, Cichon Spring 2015 UMass Dartmouth, Team 7-1, Cichon Spring 2015 회원
UMASSD-CICHON-S15S7G1
4 회원들
안내서 12개 작성하였습니다
댓글 2개
The digitizer replacement instructions was great. Thanks
steven warren - 답글
My screen is busted that has the sensor in it do I have to buy a screen or can I use a keyboard?
April sharp - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 16
전체 시간: 1,403
