소개
hello all, today we will try to repair the angelcare baby monitor.
two rechargeable battery's exploded, the acid was around an electric power cable. so there were two problems :
1 bad connection
2 battery damage.
we will check also the second unit.
필요한 것
first remove the 2 screws at the green plastic plate.
first remove the battery lid. 1 screw.
slide it out like you see in picture
remove battery's
다른 6명이 해당 안내서를 완성하였습니다.
댓글 13개
Hi. At my Angelcare (AC401) parent unit the screen has slowly become worse and worse. At first, parts of the temperature figures dissapeared, then the symbols around and now I no longer see anything... But the unit still works! (And alert me if the baby's crying) What do you think, is there anything I can do or do I need to buy a new one?
Hi There. I’m having the same problem. Did you find a fix or did you buy a new unit?
Eugene -
