이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
remove the plastic plate ( battery compartment)
you'll see that there are 2 more screws. Remove them.
now gently remove the green plastic plate arrounf the baby monitor ( arround the screen) use a spudger to click it open.
now open the monitor by clicking it open or slide it open. Sometimes its easier to use a spudger.
2 battery's were exploded so the acid was on the black electric power wire.
use a cotton swab with a little bit of destilled water.
pull the first PCB up and remove the screws of the second PCB.
after removing the two PCB's, clean the acid on the PCB.
after cleaning the PCB's put it al together again.
first remove the battery lid. 1 screw.
slide it out like you see in picture
remove battery's
다른 6명이 해당 안내서를 완성하였습니다.
댓글 13개
Hi. At my Angelcare (AC401) parent unit the screen has slowly become worse and worse. At first, parts of the temperature figures dissapeared, then the symbols around and now I no longer see anything... But the unit still works! (And alert me if the baby's crying) What do you think, is there anything I can do or do I need to buy a new one?
Hi There. I’m having the same problem. Did you find a fix or did you buy a new unit?
Eugene -
