주요 콘텐츠로 건너뛰기
Anker 2.4G Wireless Mouse DPI button Replacement
필요한 것
  1. Anker 2.4G Wireless Mouse DPI button Replacement, DPI button: 1 단계, 이미지 1개 중 1개
    • Use screwdriver to pry off the stickers marked in red to reveal the location of the 4 screws.
  2. Anker 2.4G Wireless Mouse DPI button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 4 screws to continue.
  3. Anker 2.4G Wireless Mouse DPI button Replacement: 3 단계, 이미지 2개 중 1개 Anker 2.4G Wireless Mouse DPI button Replacement: 3 단계, 이미지 2개 중 2개
    • Pry the center of the mouse apart to separate the upper and lower housing of the boards.
  4. Anker 2.4G Wireless Mouse DPI button Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the wires from the white crimp headers. this will separate the upper and lower housing units of the mouse.
    • Pull as far up on the wire as possible, being as careful as possible to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse DPI button Replacement: 5 단계, 이미지 2개 중 1개 Anker 2.4G Wireless Mouse DPI button Replacement: 5 단계, 이미지 2개 중 2개
    • Take the upper housing of the mouse and begin to remove the two screws (highlighted in red) that hold the board in place.
  6. Anker 2.4G Wireless Mouse DPI button Replacement: 6 단계, 이미지 1개 중 1개
    • Gently remove board.
  7. Anker 2.4G Wireless Mouse DPI button Replacement: 7 단계, 이미지 2개 중 1개 Anker 2.4G Wireless Mouse DPI button Replacement: 7 단계, 이미지 2개 중 2개
    • The DPI button is the red push button highlighted in red.
    • To remove it, flip the board over and desolder the wires highlighted in orange.
    • Replace component with new component and resolder back in place.
결론
작성자
2다른 기여자 명과 함께
Colin
회원 가입일: 02/10/14
406 평판
안내서 3개를 작성함
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 회원
CPSU-MANESS-W14S1G39
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 14
전체 시간: 3,598
