주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Anker 2.4G Wireless Mouse LED Replacement
필요한 것
  1. Anker 2.4G Wireless Mouse LED Replacement, LED: 1 단계, 이미지 1/1
    • Use screwdriver to gently pry off the stickers marked in red to reveal the location of the 4 screws
  2. Anker 2.4G Wireless Mouse LED Replacement: 2 단계, 이미지 1/1
    • Remove the 4 screws to continue.
  3. Anker 2.4G Wireless Mouse LED Replacement: 3 단계, 이미지 1/2 Anker 2.4G Wireless Mouse LED Replacement: 3 단계, 이미지 2/2
    • Pry the center of the mouse apart to separate upper and lower housing of the boards.
  4. Anker 2.4G Wireless Mouse LED Replacement: 4 단계, 이미지 1/1
    • Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse LED Replacement: 5 단계, 이미지 1/2 Anker 2.4G Wireless Mouse LED Replacement: 5 단계, 이미지 2/2
    • Take the upper housing of the mouse and remove the two screws (highlighted in red) that hold the board in place.
  6. Anker 2.4G Wireless Mouse LED Replacement: 6 단계, 이미지 1/1
    • Gently remove board.
  7. Anker 2.4G Wireless Mouse LED Replacement: 7 단계, 이미지 1/2 Anker 2.4G Wireless Mouse LED Replacement: 7 단계, 이미지 2/2
    • The LED is the red component on this board circled in red.
    • To remove it, flip the board over and desolder the wired highlighted in orange.
    • Replace LED with a new LED and resolder into place.
결론
Colin
회원 가입일: 02/10/14
406 평판
안내서 3개 작성하였습니다
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 회원
CPSU-MANESS-W14S1G39
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 5
전체 시간: 2,875
