주요 콘텐츠로 건너뛰기
Anker 2.4G Wireless Mouse Scroll Wheel Replacement
필요한 것
  1. Anker 2.4G Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 1/1
    • Remove the stickers from the bottom of the mouse to have access to the screws, The stickers are shown in the picture by the red rectangles.
  2. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 to remove the 4 screws shown by the red circles in the picture.
  3. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 3 단계, 이미지 1/2 Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool or spudger, on the center of the mouse, separate the upper and lower board.
  4. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 4 단계, 이미지 1/1
    • Remove the wires from the white crimp headers, separating the upper and lower housing units of the mouse. Avoid pulling the wires too hard to prevent them from breaking.
    • Don't pull the wires too hard, as they might break.
  5. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 5 단계, 이미지 1/2 Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 5 단계, 이미지 2/2
    • Pull the scroll wheel put parallel to the board.
    • This may take some force to remove. Pull the scroll wheel out parallel to the board rather than perpendicular to it.
    • Replace/clean if needed.
    • If your mouse still does not work after this step, then continue to the next instruction.
  6. Anker 2.4G Wireless Mouse Scroll Wheel Replacement: 6 단계, 이미지 1/1
    • Desolder the three pins, then solder in the replacement part.
결론
Vincent Lee
회원 가입일: 01/23/14
361 평판
안내서 3개 작성하였습니다
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 회원
CPSU-MANESS-W14S1G39
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
Hi Vincent, could you please help me with finding a place where this rotation sensor can be bought. I'm not even sure how this part is called so searching for it is quite tricky.
Cheers,
Michal
Michal Rorat - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 37
전체 시간: 8,449
