주요 콘텐츠로 건너뛰기
Anker 2.4G Wireless Mouse Side Button Replacement
필요한 것
  1. Anker 2.4G Wireless Mouse Side Button Replacement, Side Button: 1 단계, 이미지 1개 중 1개
    • Flip the mouse over so that the bottom is facing up.
    • Using a prying tool to peel off the black stickers from the bottom of the mouse.
  2. Anker 2.4G Wireless Mouse Side Button Replacement: 2 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screwdriver, remove the four screws from the bottom of the mouse.
  3. Anker 2.4G Wireless Mouse Side Button Replacement: 3 단계, 이미지 3개 중 1개 Anker 2.4G Wireless Mouse Side Button Replacement: 3 단계, 이미지 3개 중 2개 Anker 2.4G Wireless Mouse Side Button Replacement: 3 단계, 이미지 3개 중 3개
    • Pry the panels apart gently using a plastic opening tool or spudger.
    • Potential for device damage: In the pictures provided, a Phillips #0 screwdriver is used to pry open the mouse. It's important to note that this isn't proper procedure. Accidental internal damage to devices may occur when using improper prying tools. To avoid this, when prying open devices, always use plastic opening tools or spudgers.
  4. Anker 2.4G Wireless Mouse Side Button Replacement: 4 단계, 이미지 1개 중 1개
    • After separating the halves, remove the housing wires from the white crimp headers to separate the upper and lower housing units of the mouse.
    • Potential for device damage: Pull as far up on the wire as possible to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse Side Button Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two screws holding the board in place using a Phillips #0 screwdriver.
  6. Anker 2.4G Wireless Mouse Side Button Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the board from the housing unit and place it aside.
  7. Anker 2.4G Wireless Mouse Side Button Replacement: 7 단계, 이미지 3개 중 1개 Anker 2.4G Wireless Mouse Side Button Replacement: 7 단계, 이미지 3개 중 2개 Anker 2.4G Wireless Mouse Side Button Replacement: 7 단계, 이미지 3개 중 3개
    • Left on the brown-colored bottom of the board, there are two black-and-white boxes. These are the side buttons.
    • Flip the board over to reveal the green-colored side.
    • Desolder the six silver pins to disconnect the side buttons.
    • Once desoldered, remove the old side buttons.
    • Resolder the pins of the new buttons onto the board.
결론
작성자
7다른 기여자 명과 함께
Andreas Apitz
회원 가입일: 01/23/14
119 평판
안내서 1개를 작성함
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 회원
CPSU-MANESS-W14S1G39
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 20
전체 시간: 852
