이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the mouse over so that the bottom is facing up.
Using a prying tool to peel off the black stickers from the bottom of the mouse.
Using the Phillips #0 screwdriver, remove the four screws from the bottom of the mouse.
After separating the halves, remove the housing wires from the white crimp headers to separate the upper and lower housing units of the mouse.
Remove the two screws holding the board in place using a Phillips #0 screwdriver.
Left on the brown-colored bottom of the board, there are two black-and-white boxes. These are the side buttons.
Flip the board over to reveal the green-colored side.
Desolder the six silver pins to disconnect the side buttons.
Once desoldered, remove the old side buttons.
