주요 콘텐츠로 건너뛰기
Anker Soundcore 3 Battery Replacement
필요한 것
  1. Anker Soundcore 3 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Anker Soundcore 3 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Gently heat the perimeter of the device with a hairdryer to loosen the adhesive.
    • Insert a metal spudger in between the speaker's front grill and chassis.
    • Continuously pry around the edges of the casing; you should hear the glue start to separate from the front panel before the two parts separate.
  2. Anker Soundcore 3 Battery Replacement: 2 단계, 이미지 3개 중 1개 Anker Soundcore 3 Battery Replacement: 2 단계, 이미지 3개 중 2개 Anker Soundcore 3 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Remove 8 of the 10 mm screws from the speaker panel using a Phillips #0 screwdriver.
    • Using the metal spudger, gently pry at the outer-edges of the speaker to remove the rubber/plastic panel that sits above the motherboard.
    • Grip and disconnect the cable connector from both the rubber/plastic panel and the mainboard.
  3. Anker Soundcore 3 Battery Replacement: 3 단계, 이미지 2개 중 1개 Anker Soundcore 3 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 10 mm screws that secure the battery with a Phillips #00 screwdriver.
    • Firmly grasp the connector cable and gently pull up to remove it from the mainboard.
    • Remove the battery.
결론
작성자
2다른 기여자 명과 함께
Deion V
회원 가입일: 08/28/24
303 평판
안내서 3개를 작성함
1가이드 댓글
NIce, now what is the battery that can replace this one? what are the specification of the battery?
Tevin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 76
전체 시간: 784
