소개
Use this guide to replace the audio drivers in your Anker Soundcore Flare Mini. An audio driver is a device that converts electrical audio signals into soundwaves. This helps produce the audio you hear from the speaker! The drivers on most speakers are shaped like a cone to produce a certain frequency when in use. The speaker you are taking apart will have two drivers.
Before starting the replacement, make sure the speaker is turned off and is unplugged from the power cord!
Sources:
필요한 것
Remove the single 10 mm screw holding the motherboard in place using a Phillips #000 screwdriver.
Lift the motherboard up.
Remove the four 11 mm screws from the white plastic cover using a Phillips #1 screwdriver.
Remove the white plastic cover from the speaker.
Use a Phillips #1 screwdriver to remove the four 11 mm screws from one driver.
Use your hand to pull the driver out of the device.
Repeat this step with the other driver.
