소개
This guide will show you how to replace the waterproof outer shell on the Anker Soundcore Flare Mini A3167.
The waterproof outer shell protects the electronic components of the Anker Soundcore Flare Mini speaker.
Before starting the replacement, make sure the speaker is turned off and is unplugged from the power cord!
필요한 것
Remove the single 10 mm screw holding the motherboard in place using a Phillips #000 screwdriver.
Lift the motherboard up.
Remove the four 11 mm screws from the white plastic cover using a Phillips #1 screwdriver.
Remove the white plastic cover from the speaker.
다른 한 분이 해당 안내서를 완성하였습니다.
