소개
Is your Anker Soundcore Space Q45 battery not holding a charge like it used to, preventing you from using the device to its full capability? If so, here is a guide to fix the problem in a few simple steps. This guide will require you to remove the outer casing of the left headphone to access the battery.
필요한 것
Use the iFixit opening tool to disconnect six clips holding the outer covering in place.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Hi. The microphone quality of Anker Q45 is terrible. Do you think it is possible to replace de microphone for a better one?
