주요 콘텐츠로 건너뛰기
Anker Soundcore Space Q45 Bluetooth Module Replacement
필요한 것
  1. Anker Soundcore Space Q45 Bluetooth Module Replacement, Plastic Covering: 1 단계, 이미지 1개 중 1개
    • Use the iFixit opening tool to disconnect three clips holding the outer covering in place.
    • Clips at 3 o'clock, 7 o'clock and 11 o'clock
    • Image shows right headphone, battery is in left.
  2. Anker Soundcore Space Q45 Bluetooth Module Replacement: 2 단계, 이미지 2개 중 1개 Anker Soundcore Space Q45 Bluetooth Module Replacement: 2 단계, 이미지 2개 중 2개
    • Remove three screws holding the inner plastic covering in place with a Phillips screwdriver.
  3. Anker Soundcore Space Q45 Bluetooth Module Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 Anker Soundcore Space Q45 Bluetooth Module Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Remove two screws from the motherboard with a Phillips screwdriver.
    • Remove the motherboard from the headphones.
    • Insert your new motherboard
  4. Anker Soundcore Space Q45 Bluetooth Module Replacement, Bluetooth Module: 4 단계, 이미지 1개 중 1개
    • Use a soldering iron to desolder the connection from the Bluetooth receiver.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Benjamin daCosta
회원 가입일: 03/19/24
716 평판
안내서 5개를 작성함
UMass Dartmouth, Team 4-3, Shaddix Spring 2024 UMass Dartmouth, Team 4-3, Shaddix Spring 2024 회원
UMASSD-SHADDIX-S24S4G3
5 회원들
안내서 10개를 작성함
3가이드 댓글
please tell me the model of this microcircuit chip
Мидхат Миннурович - 답글
I have the sane question.. what is that chip??!! anyone???
GJN - 답글
answering myself and others out there who have their headphones stopped charging..its not the bluetooth chip.. its an IC chip..this seems to be a common problem.. the chip is ETA40543, and its not very commonly available, but you can find it on Aliexpress, about 1$ a piece.
GJN - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 36
전체 시간: 648
