주요 콘텐츠로 건너뛰기
Anker Soundcore Space Q45 Power Button Replacement
필요한 것
  1. Anker Soundcore Space Q45 Power Button Replacement, Plastic Covering: 1 단계, 이미지 1개 중 1개
    • Use the iFixit opening tool to disconnect three clips holding the outer covering in place.
    • Clips at 3 o'clock, 7 o'clock and 11 o'clock
    • Image shows right headphone, battery is in left.
  2. Anker Soundcore Space Q45 Power Button Replacement: 2 단계, 이미지 2개 중 1개 Anker Soundcore Space Q45 Power Button Replacement: 2 단계, 이미지 2개 중 2개
    • Remove three screws holding the inner plastic covering in place with a Phillips screwdriver.
  3. Anker Soundcore Space Q45 Power Button Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 Anker Soundcore Space Q45 Power Button Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Remove two screws from the motherboard with a Phillips screwdriver.
    • Remove the motherboard from the headphones.
    • Insert your new motherboard
  4. Anker Soundcore Space Q45 Power Button Replacement, Power Button: 4 단계, 이미지 1개 중 1개
    • Use a soldering iron to desolder the contacts connected to the three buttons on the bottom left-hand side of the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Benjamin daCosta
회원 가입일: 03/19/24
716 평판
안내서 5개를 작성함
UMass Dartmouth, Team 4-3, Shaddix Spring 2024 UMass Dartmouth, Team 4-3, Shaddix Spring 2024 회원
UMASSD-SHADDIX-S24S4G3
5 회원들
안내서 10개를 작성함
1가이드 댓글
guide shows how to replace the Play button on the right side of the head phones and the left side is the side with the power button and it seems like you have to disconnect the usbc ribbon cable for right side before you can do step 2
Jackson Irwin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 51
전체 시간: 639
