주요 콘텐츠로 건너뛰기
Anklet Charm Replacement
필요한 것
  1. Anklet Charm Replacement, Charm: 1 단계, 이미지 1/2 Anklet Charm Replacement, Charm: 1 단계, 이미지 2/2
    • To start, decide where on the chain you wish to place the charm. Thread the headpin through the chain link, and then place the charm on the headpin next to the chain.
  2. Anklet Charm Replacement: 2 단계, 이미지 1/1
    • Bend the head pin in half, with the chain and charm at the apex of the bend.
  3. Anklet Charm Replacement: 3 단계, 이미지 1/1
    • Cross the head pin to create a loop. Pull as tightly as possible.
  4. Anklet Charm Replacement: 4 단계, 이미지 1/1
    • Use round nose pliers and your hands to twist the head pin, closing off the loop. Make the twists as tight as possible. Twist 2-4 times.
  5. Anklet Charm Replacement: 5 단계, 이미지 1/1
    • Use semi-flush side cutters to cut the extra length off of the head pin.
  6. Anklet Charm Replacement: 6 단계, 이미지 1/1
    • Use round-nose pliers to fold the twisted head pin so it is flush with itself.
  7. Anklet Charm Replacement: 7 단계, 이미지 1/1
    • Finished!
결론
Helene Hartfield
회원 가입일: 07/27/20
145 평판
안내서 1개 작성함
UW Tacoma, Team S1-G4, Cardinal Summer 2020 UW Tacoma, Team S1-G4, Cardinal Summer 2020 회원
UWT-CARDINAL-SU20S1G4
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 23
전체 시간: 1,150
