주요 콘텐츠로 건너뛰기
Anne Pro 2 Case/Housing Replacement
필요한 것
  1. Anne Pro 2 Case/Housing Replacement, Case/Housing: 1 단계, 이미지 3개 중 1개 Anne Pro 2 Case/Housing Replacement, Case/Housing: 1 단계, 이미지 3개 중 2개 Anne Pro 2 Case/Housing Replacement, Case/Housing: 1 단계, 이미지 3개 중 3개
    • Unplug the Anne Pro 2 Keyboard.
    • Turn off the Anne Pro 2 Keyboard using the switch on the bottom.
  2. Anne Pro 2 Case/Housing Replacement: 2 단계, 이미지 2개 중 1개 Anne Pro 2 Case/Housing Replacement: 2 단계, 이미지 2개 중 2개
    • Using a keycap remover, remove the the following keycaps: Left Alt, Space Bar, Right Shift, Backslash, Y, H, and the Tab key.
  3. Anne Pro 2 Case/Housing Replacement: 3 단계, 이미지 2개 중 1개 Anne Pro 2 Case/Housing Replacement: 3 단계, 이미지 2개 중 2개
    • Using a Torx T5 bit, remove the five screws from the keyboard.
  4. Anne Pro 2 Case/Housing Replacement: 4 단계, 이미지 2개 중 1개 Anne Pro 2 Case/Housing Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the keyboard slowly from the bottom side.
    • Do not fully lift the PCB because the battery is still plugged in.
  5. Anne Pro 2 Case/Housing Replacement: 5 단계, 이미지 2개 중 1개 Anne Pro 2 Case/Housing Replacement: 5 단계, 이미지 2개 중 2개
    • Gently unplug the battery connector by wiggling it back and forth.
  6. Anne Pro 2 Case/Housing Replacement: 6 단계, 이미지 2개 중 1개 Anne Pro 2 Case/Housing Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the PCB from the main case.
    • Gently lower the PCB into the Zero-Degree housing from the top side first.
    • Firmly press it in once you have lowered it.
  7. Anne Pro 2 Case/Housing Replacement: 7 단계, 이미지 2개 중 1개 Anne Pro 2 Case/Housing Replacement: 7 단계, 이미지 2개 중 2개
    • Screw the five T5 Torx screws back into place.
  8. Anne Pro 2 Case/Housing Replacement: 8 단계, 이미지 2개 중 1개 Anne Pro 2 Case/Housing Replacement: 8 단계, 이미지 2개 중 2개
    • Take the seven keycaps you removed and gently place them in their intended spots on the keyboard.
    • Firmly press them in, ensuring they are flush with the rest of the keys.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mohamed
회원 가입일: 09/15/20
205 평판
안내서 1개를 작성함
York University, Team S2-G3, Melo-Thaiss Fall 2020 York University, Team S2-G3, Melo-Thaiss Fall 2020 회원
YORK-MELO-THAISS-F20S2G3
1 회원
안내서 2개를 작성함
1가이드 댓글
Anne Pro 2 Software manage the illumination, open the mobile App and choose a pre-programmed scheme or design your own pattern, with a distinct colour for each key if desired. The programmes are easy to use and work on both Mac and PC.
Visit Here-   https://www.techtoreview.com/top-picks/a...
Abhinav Pal - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 84
전체 시간: 11,573
