주요 콘텐츠로 건너뛰기
Anne Pro 2 Keyboard Keycaps Replacement
필요한 것
  1. Anne Pro 2 Keyboard Keycaps Replacement, Keycaps: 1 단계, 이미지 1/1
    • Set the keyboard down on a flat surface. Make sure it is turned off and is not connected to a power source.
  2. Anne Pro 2 Keyboard Keycaps Replacement: 2 단계, 이미지 1/3 Anne Pro 2 Keyboard Keycaps Replacement: 2 단계, 이미지 2/3 Anne Pro 2 Keyboard Keycaps Replacement: 2 단계, 이미지 3/3
    • Use the keycap remover to remove the key caps from left to right.
    • Remove the smaller keycaps first so the surrounding larger caps can be removed more easily.
  3. Anne Pro 2 Keyboard Keycaps Replacement: 3 단계, 이미지 1/2 Anne Pro 2 Keyboard Keycaps Replacement: 3 단계, 이미지 2/2
    • Use the compressed air to remove all dust and hair from the keyboard.
    • Focus on the red key switches to make sure all dust and hair are removed from inside.
  4. Anne Pro 2 Keyboard Keycaps Replacement: 4 단계, 이미지 1/1
    • New replacement keycaps can be used here, but if you see no damage to older keycaps they can be re-used.
    • Use the keycap remover to set in the keycaps starting from the bottom to the top.
  5. Anne Pro 2 Keyboard Keycaps Replacement: 5 단계, 이미지 1/1
    • Inspect the final product, making sure all keycaps are back in the right place and functioning.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Omar Sukkar
회원 가입일: 11/24/20
145 평판
안내서 1개 작성함
University of Memphis, Team S4-G5, Kim Fall 2020 University of Memphis, Team S4-G5, Kim Fall 2020 회원
UM-KIM-F20S4G5
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 38
전체 시간: 1,939
