소개
In this guide, users will learn about some of the internal workings of some older lamps. The lamp in this guide is actually a lamp from my grandmother. It was one of her favorite lamps for its unique patterns it throws on the room around it. It's a simple replacement of the threaded center support that just requires a bit of disassembly to get to it, once that is all done the lamp is reassembled the same way it came apart.
필요한 것
Start by unscrewing the decorative nut from the top of the canopy. Then lift the canopy off the old support.
The threaded rod and coupling may need a hole for the wires to pass through. Remove the coupling and rod from the light fixture; do not move the coupler up the threaded rod. The coupler's location will serve as a reference for the hole.
Make a hole with the drill; if the size of the whole needed is unknown, a stepped drill bit is useful. Do not apply too much pressure as the metal is likely soft.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Thanks for sharing this blog. For lamps and home decor items please visit Lavish home decors. They provide elite home decor products at reasonable rates.
