소개
In this guide, users will learn about some of the internal workings of some older lamps. The lamp in this guide is actually a lamp from my grandmother. It was one of her favorite lamps for its unique patterns it throws on the room around it. It's a simple replacement of the threaded center support that just requires a bit of disassembly to get to it, once that is all done the lamp is reassembled the same way it came apart.
필요한 것
Start by unscrewing the decorative nut from the top of the canopy. Then lift the canopy off the old support.
The threaded rod and coupling may need a hole for the wires to pass through. Remove the coupling and rod from the light fixture; do not move the coupler up the threaded rod. The coupler's location will serve as a reference for the hole.
Make a hole with the drill; if the size of the whole needed is unknown, a stepped drill bit is useful. Do not apply too much pressure as the metal is likely soft.
The hole only needs to be big enough for the wires to pass through, and once that's done, the lamp can be re-assembled just the way it was put together. Let there be light!
Thanks for posting this. I happen to have this same lamp, and it is missing the finial, or decorative nut, at the top of the lamp. I measure 2 1/2 inches for the missing finial. Is this the same measurement as yours? Do you know where I can find a replacement? Thanks!
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Thanks for sharing this blog. For lamps and home decor items please visit Lavish home decors. They provide elite home decor products at reasonable rates.
