주요 콘텐츠로 건너뛰기
Antique Singer sewing machine 1935 Thread adjustable guide Replacement
  1. Antique Singer sewing machine 1935 Thread adjustable guide Replacement, Missing thread guide: 1 단계, 이미지 1개 중 1개
    • The machine is missing the thread guide as shown here. Otherwise, it is operational.
  2. Antique Singer sewing machine 1935 Thread adjustable guide Replacement, Machining the elements: 2 단계, 이미지 2개 중 1개 Antique Singer sewing machine 1935 Thread adjustable guide Replacement, Machining the elements: 2 단계, 이미지 2개 중 2개
    • You will need a lathe to machine appropriately sized elements to replace the mechanism.
    • I used alumunium for the machined elements. Use high speed to obtain smooth surface as you need the thread to slide correctly.
    • The assembly may be done used an M5 screw and a cone spring as shown.
결론
작성자
1다른 기여자 명과 함께
Michal Ruzek
회원 가입일: 01/27/22
739 평판
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 17
전체 시간: 247
