주요 콘텐츠로 건너뛰기
Aorus 15P XD SSD Replacement
필요한 것
  1. Aorus 15P XD SSD Replacement, SSD: 1 단계, 이미지 2개 중 1개 Aorus 15P XD SSD Replacement, SSD: 1 단계, 이미지 2개 중 2개
    • First, make sure the power is off and disconnect the power.
    • Use a Torx security screwdriver to remove twelve 1.2 mm screws from the back case.
    • Use an opening tool to gently separate the front and back case. Work your way around the perimeter of the laptop and undo the clips holding it together.
    • Remove the back case.
  2. Aorus 15P XD SSD Replacement: 2 단계, 이미지 3개 중 1개 Aorus 15P XD SSD Replacement: 2 단계, 이미지 3개 중 2개 Aorus 15P XD SSD Replacement: 2 단계, 이미지 3개 중 3개
    • Use a JIS screwdriver to remove the single 8 mm screw securing the SSD in place.
    • Slide the SSD out of the socket connected to the motherboard.
    • Slide your new or upgraded SSD in the socket securely and replace the 8 mm screw.
  3. Aorus 15P XD SSD Replacement: 3 단계, 이미지 1개 중 1개
    • Set the back case on the laptop but don't replace the screws yet.
  4. Aorus 15P XD SSD Replacement: 4 단계, 이미지 3개 중 1개 Aorus 15P XD SSD Replacement: 4 단계, 이미지 3개 중 2개 Aorus 15P XD SSD Replacement: 4 단계, 이미지 3개 중 3개
    • Turn the device back on and open the advanced storage settings.
    • Choose the storage used on other drivers.
    • Next, check if the storage you installed is recognized in local disk storage.
  5. Aorus 15P XD SSD Replacement: 5 단계, 이미지 2개 중 1개 Aorus 15P XD SSD Replacement: 5 단계, 이미지 2개 중 2개
    • If the storage is detected, replace the screws.
    • If your storage is not detected, open the back case to make sure the SSD is plugged in tightly to the socket. If not, go back to Step 2.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Weitao Shi
회원 가입일: 07/02/22
142 평판
안내서 1개를 작성함
York University, Team M-26, Allen Summer 2022 York University, Team M-26, Allen Summer 2022 회원
YORK-ALLEN-SU22SMG26
1 회원
안내서 2개를 작성함
3가이드 댓글
Thanks, does the new SSD need thermal pad as well? And if so what thickness?
Martijn Spits - 답글
Yes. what thickness is required? and which one is gen 3 and gen 4 slots?
Mark Jose -
I read that the one slot can be used for gen3 or sata, however I don't see where might the sata drive can be placed inside this laptop.
Mark Jose - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 36
지난 30일: 126
전체 시간: 6,146
