주요 콘텐츠로 건너뛰기
Aorus X7 v2 I/O Board Replacement
필요한 것
  1. Aorus X7 v2 I/O Board Replacement, I/O Board: 1 단계, 이미지 1/3 Aorus X7 v2 I/O Board Replacement, I/O Board: 1 단계, 이미지 2/3 Aorus X7 v2 I/O Board Replacement, I/O Board: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    T5 Torx Screwdriver
    $5.49
    구매
    • First, power off your laptop and unplug all cables and accessories. Then, place it upside down on a stable and flat surface.
    • Use the T5 Torx Screwdriver to remove the 12 screws on the bottom of the laptop. Once the screws are removed, lift off the bottom panel.
    • Locate the speaker on the right-hand side of the device.
    • Remove the four red and black braided cables by gripping the black plastic piece on each cable and gently tugging to separate it from the white outlet.
  2. Aorus X7 v2 I/O Board Replacement: 2 단계, 이미지 1/3 Aorus X7 v2 I/O Board Replacement: 2 단계, 이미지 2/3 Aorus X7 v2 I/O Board Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Phillips #0 Screwdriver
    $5.49
    구매
    • Use the Phillips #0 Screwdriver to remove the two screws holding the speaker in place. Lift off the speaker panel.
    • Use the Phillips #0 Screwdriver to remove the three screws holding the board in place.
    • Carefully pull the two black tabs on either side of the black ribbon to disconnect them from the board.
  3. Aorus X7 v2 I/O Board Replacement: 3 단계, 이미지 1/3 Aorus X7 v2 I/O Board Replacement: 3 단계, 이미지 2/3 Aorus X7 v2 I/O Board Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    $5.49
    구매
    • Gently pull off the inner black ribbon to remove it from the board.
    • Use the Phillips #0 Screwdriver to remove the screw.
    • Place a finger under the board (see photo for location reference) and slowly lift up to remove the board.
결론
Complete these steps in reverse order to install your new I/O Board.
다른 한 분이 해당 안내서를 완성하였습니다.
Alexis Hernandez Jimenez
회원 가입일: 08/25/22
572 평판
안내서 5개 작성하였습니다
Gateway, Team 1-4, Pee Fall 2022 Gateway, Team 1-4, Pee Fall 2022 회원
GCC-PEE-F22S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 17
전체 시간: 347
