주요 콘텐츠로 건너뛰기
Aorus x7 v2 Fan Assembly Replacement
필요한 것
  1. Aorus x7 v2 Fan Assembly Replacement, Fan Assembly: 1 단계, 이미지 1/3 Aorus x7 v2 Fan Assembly Replacement, Fan Assembly: 1 단계, 이미지 2/3 Aorus x7 v2 Fan Assembly Replacement, Fan Assembly: 1 단계, 이미지 3/3
    • Flip the laptop over.
    • Unscrew the 12 screws holding on the bottom cover.
    • Take off the bottom cover.
    • Remove the 12 screws from the heat sink.
  2. Aorus x7 v2 Fan Assembly Replacement: 2 단계, 이미지 1/3 Aorus x7 v2 Fan Assembly Replacement: 2 단계, 이미지 2/3 Aorus x7 v2 Fan Assembly Replacement: 2 단계, 이미지 3/3
    • Remove the heat sinks one by one.
  3. Aorus x7 v2 Fan Assembly Replacement: 3 단계, 이미지 1/3 Aorus x7 v2 Fan Assembly Replacement: 3 단계, 이미지 2/3 Aorus x7 v2 Fan Assembly Replacement: 3 단계, 이미지 3/3
    • Unscrew the six screws from the right fan.
    • Unscrew the six screws from the left fan.
    • Locate the connection plug for the fan to the motherboard and disconnect the left fan connector.
  4. Aorus x7 v2 Fan Assembly Replacement: 4 단계, 이미지 1/3 Aorus x7 v2 Fan Assembly Replacement: 4 단계, 이미지 2/3 Aorus x7 v2 Fan Assembly Replacement: 4 단계, 이미지 3/3
    • Disconnect the right fan connector.
    • Carefully lift up the left and right fans.
    • Set the fans to the side before installing new fans.
결론
To reassemble your device, follow these instructions in reverse order using new left and right fans.
Alexis Hernandez Jimenez
회원 가입일: 08/25/22
572 평판
안내서 5개 작성하였습니다
Gateway, Team 1-4, Pee Fall 2022 Gateway, Team 1-4, Pee Fall 2022 회원
GCC-PEE-F22S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 28
전체 시간: 387
