주요 콘텐츠로 건너뛰기
Aoson R103 Speakers Replacement
필요한 것
  1. Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: 1 단계, 이미지 1/3 Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: 1 단계, 이미지 2/3 Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: 1 단계, 이미지 3/3
    • Turn off the device using the power button.
    • Using fingernails/a pry tool, separate the back panel of the device. This may decent force as they are connected by push tabs.
    • Be careful not to drop the device when separating, this could cause permanent damage.
    • This will expose the motherboard of the device.
  2. Aoson R103 Speakers Replacement: 2 단계, 이미지 1/2 Aoson R103 Speakers Replacement: 2 단계, 이미지 2/2
    • Use your fingers to unclip the ribbon connecter and then pull the ribbon out of the connector.
    • This ribbon connects the power button and stops the device from turning on; allowing further procedure.
  3. Aoson R103 Speakers Replacement, Speakers: 3 단계, 이미지 1/3 Aoson R103 Speakers Replacement, Speakers: 3 단계, 이미지 2/3 Aoson R103 Speakers Replacement, Speakers: 3 단계, 이미지 3/3
    • The motherboard connections to the speaker are circled, they will be needed later.
    • The two speakers are circled in orange, they are attached to a plastic piece via a screw.
    • The 4.0mm long philips-head 00 screw will be disconnected at the Boxed area where the plastic disconnects.
    • Be careful not to disconnect the back ground wire when taking the plastic off.
  4. Aoson R103 Speakers Replacement: 4 단계, 이미지 1/2 Aoson R103 Speakers Replacement: 4 단계, 이미지 2/2
    • The box contains the four (4) soldering connections for the two speakers. Unsolder the old speakers and solder the new speakers in.
    • Be sure to match up the appropriately placed speaker to its correct positive or negative node. mixing these up could distort audio or fry the speakers.
    • Note: solder over a piece of paper where you can mark each node with a red or black marker to denote positive and negative nodes for the left or right speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Louis
회원 가입일: 02/14/23
208 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 153
