소개
This guide will show the user how to remove and replace the battery on the Apex TM772.
필요한 것
Begin by inserting the plastic opening tool into the seam between the back and front of the case and carefully pry the back from the front.
이 단계에 사용된 도구:Plastic Cards$2.99
Using tweezers or your fingers, remove the yellow tape from the battery.
Using a plastic card or nylon tool, carefully separate battery from case by sliding the tool under battery to loosen adhesive.
Solder the wire connection of the red wire to the positive (+) position on the left
Solder the wire connection of the yellow wire to the center position that is slightly above the positive (+) and the negative (-) positions. This is the ground.
Solder the wire connection of the black wire to the negative (-) position on the right.
