주요 콘텐츠로 건너뛰기
Apple AirPort Extreme Model A1034 Antenna Replacement
필요한 것
  1. Apple AirPort Extreme Model A1034 Antenna Replacement, Outer Case: 1 단계, 이미지 1/1
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Antenna Replacement: 2 단계, 이미지 1/1
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Antenna Replacement: 3 단계, 이미지 1/2 Apple AirPort Extreme Model A1034 Antenna Replacement: 3 단계, 이미지 2/2
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Antenna Replacement: 4 단계, 이미지 1/1
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Antenna Replacement, Antenna: 5 단계, 이미지 1/1
    • Remove the two 4mm phillips screws to remove antenna.
  6. Apple AirPort Extreme Model A1034 Antenna Replacement: 6 단계, 이미지 1/1
    • The circuit board connected to the antenna is attached to the metal case with foam adhesive.
    • Gently peel or cut the foam holding the circuit board with a knife and remove it from the AirPort.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Garcia
회원 가입일: 10/12/11
411 평판
안내서 5개 작성하였습니다
Cal Poly, Team 17-15, Regan Fall 2011 Cal Poly, Team 17-15, Regan Fall 2011 회원
CPSU-REGAN-F11S17G15
3 회원들
안내서 13개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 18
전체 시간: 4,571
