주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Apple AirPort Extreme Model A1034 Motherboard Replacement
필요한 것
  1. Apple AirPort Extreme Model A1034 Motherboard Replacement, Outer Case: 1 단계, 이미지 1/1
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Motherboard Replacement: 3 단계, 이미지 1/2 Apple AirPort Extreme Model A1034 Motherboard Replacement: 3 단계, 이미지 2/2
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Motherboard Replacement: 4 단계, 이미지 1/1
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Remove the four 4.3mm phillips screws from the bottom of the metal casing.
  6. Apple AirPort Extreme Model A1034 Motherboard Replacement: 6 단계, 이미지 1/1
    • Lift and separate the top and bottom of the metal casing. You will now expose the motherboard and the AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
  7. Apple AirPort Extreme Model A1034 Motherboard Replacement: 7 단계, 이미지 1/1
    • Locate and remove the three 5.0mm phillips screws from the heat sink.
    • Lift to remove the heat sink from the motherboard.
  8. Apple AirPort Extreme Model A1034 Motherboard Replacement: 8 단계, 이미지 1/2 Apple AirPort Extreme Model A1034 Motherboard Replacement: 8 단계, 이미지 2/2
    • Locate and remove the five 7.5mm phillips screws from the motherboard.
    • Lift and separate the motherboard from the bottom metal casing.
    • There will be a loose hexagonal female screw extender under the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Michael Garcia
회원 가입일: 10/12/11
411 평판
안내서 5개 작성하였습니다
Cal Poly, Team 17-15, Regan Fall 2011 Cal Poly, Team 17-15, Regan Fall 2011 회원
CPSU-REGAN-F11S17G15
3 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 5,970
