주요 콘텐츠로 건너뛰기
Apple AirPort Extreme Model A1143 Logic Board Replacement
필요한 것
  1. Apple AirPort Extreme Model A1143 Logic Board Replacement, Back Pad: 1 단계, 이미지 1개 중 1개
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
  2. Apple AirPort Extreme Model A1143 Logic Board Replacement, Back Cover: 2 단계, 이미지 1개 중 1개
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Apple AirPort Extreme Model A1143 Logic Board Replacement: 3 단계, 이미지 1개 중 1개
    • Lift up the back case from the perforated edge to remove it.
  4. Apple AirPort Extreme Model A1143 Logic Board Replacement, Remove from Case: 4 단계, 이미지 1개 중 1개
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
  5. Apple AirPort Extreme Model A1143 Logic Board Replacement, Detach Logic Board From Case: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
  6. Apple AirPort Extreme Model A1143 Logic Board Replacement, Pull Back Tabs: 6 단계, 이미지 1개 중 1개
    • Carefully push back the three metal tabs with your fingers on the sides of metal case.
  7. Apple AirPort Extreme Model A1143 Logic Board Replacement, Remove Metal case: 7 단계, 이미지 1개 중 1개
    • Carefully pull the metal case away from the logic board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Zak
회원 가입일: 09/23/14
622 평판
안내서 4개를 작성함
USF Tampa, Team 12-4, Blackwell Fall 2014 USF Tampa, Team 12-4, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S12G4
5 회원들
안내서 10개를 작성함
1가이드 댓글
my apple a1143 wont turn on at all no light.
what can it be done?
Gabriel barradenguy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 21
전체 시간: 2,819
