주요 콘텐츠로 건너뛰기
Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement
필요한 것
  1. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Back Pad: 1 단계, 이미지 1개 중 1개
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
  2. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Back Cover: 2 단계, 이미지 1개 중 1개
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement: 3 단계, 이미지 1개 중 1개
    • Lift up the back case from the perforated edge to remove it.
  4. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Remove from Case: 4 단계, 이미지 1개 중 1개
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
  5. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Detach Logic Board From Case: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
  6. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Pull Back Tabs: 6 단계, 이미지 1개 중 1개
    • Carefully push back the three metal tabs with your fingers on the sides of metal case.
  7. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Remove Metal case: 7 단계, 이미지 1개 중 1개
    • Carefully pull the metal case away from the logic board.
  8. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement, Wi-Fi Antenna: 8 단계, 이미지 1개 중 1개
    • Unscrew the 5mm #00 screws from each of the three antennas located on the sides of the metal casing.
    • Pull away antennas from metal case.
  9. Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement: 9 단계, 이미지 2개 중 1개 Apple AirPort Extreme Model A1143 Wi-Fi Antenna Replacement: 9 단계, 이미지 2개 중 2개
    • Pull up the less visible silver tape that holds the antenna cords in place at the ends of the device using your fingers.
    • Remove clear yellow tape that holds the cords to the outer casing in the same manner.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dillon Huffsmith
회원 가입일: 09/23/14
295 평판
안내서 1개를 작성함
USF Tampa, Team 12-4, Blackwell Fall 2014 USF Tampa, Team 12-4, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S12G4
5 회원들
안내서 10개를 작성함
2가이드 댓글
Thanks for the guide.
Pulled mine apart to examine the battery inside. It measured above 3.1 volts - even though it has been in use since June 2008 (about 9 years).
Holes will be punched for access to the 5 screws so the rubber pad does not have to be removed if it needs to be opened in the future.
I may see about buying a new Ac adapter to power this Airport Extreme since that is probably why the status light on the front did not illuminate.
doctordon - 답글
Completed this. Didnt use apple replacement antennas. Added 3 U.FL Mini PCI to RP-SMA Pigtails, drilled 3 holes and mounted 3 +9db antennas. My wifi finally reaches my garage
David Bunting - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 12
전체 시간: 1,909
