주요 콘텐츠로 건너뛰기
Apple AirPort Extreme Model A1354 Back Pad Replacement
필요한 것
  1. Apple AirPort Extreme Model A1354 Back Pad Replacement, Back Pad: 1 단계, 이미지 1/1
    • Caution: the back pad is secured with glue so remove it gently to avoid ripping the pad. You may have to repeatedly pull and release to loosen up the glue.
    • First start by peeling off the outer rubbery covering on the bottom of the device. This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
    • Continue peeling back on the pad until it is removed.
  2. Apple AirPort Extreme Model A1354 Back Pad Replacement: 2 단계, 이미지 1/1
    • Place double sided tape along the sides of the bottom of the device as shown, this will allow for the rubber cover to stick back on but still be accessible in the future
    • Repeat steps for all four sides
  3. Apple AirPort Extreme Model A1354 Back Pad Replacement: 3 단계, 이미지 1/1
    • Line up rubber cover along the bottom of the device.
    • Press down firmly to secure the rubber cover onto place.
결론
To disassemble your device look at device disassembly on the main page.
다른 2명이 해당 안내서를 완성하였습니다.
Alex Ly
회원 가입일: 04/02/12
201 평판
안내서 2개 작성하였습니다
Cal Poly, Team 5-2, Forte Spring 2012 Cal Poly, Team 5-2, Forte Spring 2012 회원
CPSU-FORTE-S12S5G2
5 회원들
안내서 12개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 2,955
