소개
If all other troubleshooting options fail, you may need to replace the logic board.
도구
부품
지정된 부품이 없습니다.
First start by peeling off the outer rubbery covering on the bottom of the device.
Take the device out of the casing and orient it so that you can see the WiFi card.
Remove the metal casing by gently prying the logic board away with you hands.
This should be pretty easy, you already removed the screws holding these pieces together.
This is the "naked" logic board. You can order a new one and replace it by following the above steps in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
