주요 콘텐츠로 건너뛰기
Apple AirPort Extreme Model A1354 Outer Case Replacement
필요한 것
  1. Apple AirPort Extreme Model A1354 Outer Case Replacement, Outer Case: 1 단계, 이미지 1/1
    • First start by peeling off the outer rubbery covering on the bottom of the device.
    • CAUTION: This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
  2. Apple AirPort Extreme Model A1354 Outer Case Replacement: 2 단계, 이미지 1/1
    • After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
  3. Apple AirPort Extreme Model A1354 Outer Case Replacement: 3 단계, 이미지 1/1
    • After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
  4. Apple AirPort Extreme Model A1354 Outer Case Replacement: 4 단계, 이미지 1/3 Apple AirPort Extreme Model A1354 Outer Case Replacement: 4 단계, 이미지 2/3 Apple AirPort Extreme Model A1354 Outer Case Replacement: 4 단계, 이미지 3/3
    • The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
    • It should make a click when it comes apart.
  5. Apple AirPort Extreme Model A1354 Outer Case Replacement: 5 단계, 이미지 1/1
    • Remove the outer casing.
    • The exposed logic board should look like this.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brandon
회원 가입일: 04/02/12
387 평판
안내서 3개 작성하였습니다
Cal Poly, Team 5-2, Forte Spring 2012 Cal Poly, Team 5-2, Forte Spring 2012 회원
CPSU-FORTE-S12S5G2
5 회원들
안내서 12개 작성하였습니다
댓글 한 개
This guide also applies to model A1408.
Jonas Nilsson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 4,299
