주요 콘텐츠로 건너뛰기
Apple AirPort Extreme Model A1354 WiFi Card Replacement
필요한 것
  1. Apple AirPort Extreme Model A1354 WiFi Card Replacement, Outer Case: 1 단계, 이미지 1/1
    • First start by peeling off the outer rubbery covering on the bottom of the device.
    • CAUTION: This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
  2. Apple AirPort Extreme Model A1354 WiFi Card Replacement: 2 단계, 이미지 1/1
    • After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
  3. Apple AirPort Extreme Model A1354 WiFi Card Replacement: 3 단계, 이미지 1/1
    • After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
  4. Apple AirPort Extreme Model A1354 WiFi Card Replacement: 4 단계, 이미지 1/3 Apple AirPort Extreme Model A1354 WiFi Card Replacement: 4 단계, 이미지 2/3 Apple AirPort Extreme Model A1354 WiFi Card Replacement: 4 단계, 이미지 3/3
    • The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
    • It should make a click when it comes apart.
  5. Apple AirPort Extreme Model A1354 WiFi Card Replacement: 5 단계, 이미지 1/1
    • Remove the outer casing.
    • The exposed logic board should look like this.
  6. Apple AirPort Extreme Model A1354 WiFi Card Replacement, WiFi Card: 6 단계, 이미지 1/1
    • Take the device out of the casing and orient it so that you can see the WiFi card.
  7. Apple AirPort Extreme Model A1354 WiFi Card Replacement: 7 단계, 이미지 1/1
    • Wires come from the three antennas and connect on the outer edge of the WiFi card.
    • Carefully pull up on the end of one of the wires to disconnect it from the motherboard.
    • Do this for the remaining two wires.
  8. Apple AirPort Extreme Model A1354 WiFi Card Replacement: 8 단계, 이미지 1/1
    • There are two clips attached to the upper and lower ends of the WiFi card
    • CAUTION: For the following step, do not pull the clip after you have detached it. The clip is fragile and too much force may cause the clip to break.
    • Grab the end of one of the clips and pull away from the WiFi card. This should make the clip visibly detached from the WiFi card.
    • Do the same for the other clip.
  9. Apple AirPort Extreme Model A1354 WiFi Card Replacement: 9 단계, 이미지 1/2 Apple AirPort Extreme Model A1354 WiFi Card Replacement: 9 단계, 이미지 2/2
    • Grasp the upper and lower ends of the WiFi card.
    • Carefully pull the WiFi card to the right.
    • CAUTION: Do not pull UP (towards yourself) on the WiFi card when removing. The card is on a track that only allows it to move left and right. Forcing the card to move in other directions may result in breaking the track.
    • Completely remove the WiFi card.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Daniel Wagstaffe
회원 가입일: 04/02/12
115 평판
안내서 1개 작성함
Cal Poly, Team 5-2, Forte Spring 2012 Cal Poly, Team 5-2, Forte Spring 2012 회원
CPSU-FORTE-S12S5G2
5 회원들
안내서 12개 작성하였습니다
댓글 한 개
this is a1143 model not a1354
allls - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 22
전체 시간: 9,038
