이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
First start by peeling off the outer rubbery covering on the bottom of the device.
After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
It should make a click when it comes apart.
Remove the outer casing.
The exposed logic board should look like this.
Take the device out of the casing and orient it so that you can see the WiFi card.
Wires come from the three antennas and connect on the outer edge of the WiFi card.
Carefully pull up on the end of one of the wires to disconnect it from the motherboard.
Do this for the remaining two wires.
There are two clips attached to the upper and lower ends of the WiFi card
Grab the end of one of the clips and pull away from the WiFi card. This should make the clip visibly detached from the WiFi card.
Do the same for the other clip.
Grasp the upper and lower ends of the WiFi card.
Carefully pull the WiFi card to the right.
Completely remove the WiFi card.
다른 3명이 해당 안내서를 완성하였습니다.
