주요 콘텐츠로 건너뛰기
Apple Airport Extreme Model A1408 Antenna Replacement
필요한 것
  1. Apple Airport Extreme Model A1408 Antenna Replacement, Back Pad: 1 단계, 이미지 1/1
    • CAUTION: The heat gun and hair dryer can get very hot. Do not put your hands or any other body part too close to either device. Also, do not touch the back pad right after heating it.
    • Use a blow dryer or heat gun on a medium to high heat setting on the back pad to loosen the glue that attaches it to the device.
  2. Apple Airport Extreme Model A1408 Antenna Replacement: 2 단계, 이미지 1/1
    • To avoid ripping the back pad, gently peel it back from one corner until the pad is completely off.
    • Use heat in areas where the glue is not loose enough.
    • You may need to reattach the back pad with double-sided tape if the glue is not tacky enough to stick the pad back on.
  3. Apple Airport Extreme Model A1408 Antenna Replacement, Outer Case: 3 단계, 이미지 1/2 Apple Airport Extreme Model A1408 Antenna Replacement, Outer Case: 3 단계, 이미지 2/2
    • After removing the back pad, unscrew the five 5 mm Phillips #00 screws in the large, deep holes in the plastic casing. The plastic casing should come off easily after removing all the screws.
    • When installing the plastic back cover, ensure the lip is aligned with the ports on the back of the device.
  4. Apple Airport Extreme Model A1408 Antenna Replacement: 4 단계, 이미지 1/2 Apple Airport Extreme Model A1408 Antenna Replacement: 4 단계, 이미지 2/2
    • Insert a narrow plastic opening tool into one of the notches. Apply moderate force to pull the metal casing from the plastic outer casing. You can use the rim of the outer case as leverage. You should hear a click when the metal casing detaches.
    • After you hear the click, remove the inner metal case from the outer case using your hands. It should not take very much force.
  5. Apple Airport Extreme Model A1408 Antenna Replacement, Logic Board: 5 단계, 이미지 1/2 Apple Airport Extreme Model A1408 Antenna Replacement, Logic Board: 5 단계, 이미지 2/2
    • Remove the four wires coming from the antennas by pinching the cable at the tip and gently pulling up on it until it pops out of the socket.
    • Repeat for the remaining three wires.
    • You might need to wiggle the wire to free it from the socket.
  6. Apple Airport Extreme Model A1408 Antenna Replacement: 6 단계, 이미지 1/2 Apple Airport Extreme Model A1408 Antenna Replacement: 6 단계, 이미지 2/2
    • Separate the logic board from the inner metal casing by gently pushing up on the logic board from the bottom while holding down the casing edges.
    • Pull the logic board away from the metal casing to separate the two.
  7. Apple Airport Extreme Model A1408 Antenna Replacement, Antenna: 7 단계, 이미지 1/1
    • The four antennae are located here. Select the one you are replacing.
  8. Apple Airport Extreme Model A1408 Antenna Replacement: 8 단계, 이미지 1/1
    • Remove the 5 mm Phillips #00 screw holding the blue antenna to the logic board.
  9. Apple Airport Extreme Model A1408 Antenna Replacement: 9 단계, 이미지 1/1
    • Remove the tape that attaches the wire to the logic board.
  10. Apple Airport Extreme Model A1408 Antenna Replacement: 10 단계, 이미지 1/1
    • Lift wire out of its port. You should have one free end now.
  11. Apple Airport Extreme Model A1408 Antenna Replacement: 11 단계, 이미지 1/1
    • Finish by lifting the antenna out of its position. The antenna and wire should be free from the logic board at this time and ready for replacement.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Evan
회원 가입일: 10/14/14
146 평판
안내서 1개 작성함
Cal Poly, Team 10-37, Amido Fall 2014 Cal Poly, Team 10-37, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G37
4 회원들
안내서 12개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 31
전체 시간: 3,740
