주요 콘텐츠로 건너뛰기
Apple Airport Extreme Model A1408 Back Pad Replacement
필요한 것
  1. Apple Airport Extreme Model A1408 Back Pad Replacement, Back Pad: 1 단계, 이미지 1/1
    • CAUTION: The heat gun and hair dryer can get very hot. Do not put your hands or any other body part too close to either device. Also, do not touch the back pad right after heating it.
    • Use a blow dryer or heat gun on a medium to high heat setting on the back pad to loosen the glue that attaches it to the device.
  2. Apple Airport Extreme Model A1408 Back Pad Replacement: 2 단계, 이미지 1/1
    • To avoid ripping the back pad, gently peel it back from one corner until the pad is completely off.
    • Use heat in areas where the glue is not loose enough.
    • You may need to reattach the back pad with double-sided tape if the glue is not tacky enough to stick the pad back on.
결론
To reassemble your device, follow these instructions in reverse order without using the hair dryer.
Jada Evers
회원 가입일: 10/14/14
296 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-37, Amido Fall 2014 Cal Poly, Team 10-37, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G37
4 회원들
안내서 12개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 14
전체 시간: 1,903
