소개
This guide will show you how to gain access to the LCD Control Board on an Apple Cinema Display. The tools required for this section are the supurger and the PH 2 screwdriver.
도구
부품
지정된 부품이 없습니다.
Flip the Cinema Display so it is on its face and the feet are pointed away from you.
Using the PH 2 screw driver, unscrew the three feet screws (9.52 x 4.43mm).
Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
Locate and carefully remove the two tape plugs on either side of the control board using the spudger.
다른 한 분이 해당 안내서를 완성하였습니다.
