이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you how to gain access to the LCD Control Board on an Apple Cinema Display. The tools required for this section are the supurger and the PH 2 screwdriver.
필요한 것
Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
Locate and carefully remove the two tape plugs on either side of the control board using the spudger.
다른 한 분이 해당 안내서를 완성하였습니다.
