주요 콘텐츠로 건너뛰기
Apple Cinema Display M8149 LCD Screen Replacement
필요한 것
  1. Apple Cinema Display M8149 LCD Screen Replacement, Control Boards: 1 단계, 이미지 1/3 Apple Cinema Display M8149 LCD Screen Replacement, Control Boards: 1 단계, 이미지 2/3 Apple Cinema Display M8149 LCD Screen Replacement, Control Boards: 1 단계, 이미지 3/3
    • Before starting, make sure the display is unplugged.
    • Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
    • Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
    • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
  2. Apple Cinema Display M8149 LCD Screen Replacement: 2 단계, 이미지 1/3 Apple Cinema Display M8149 LCD Screen Replacement: 2 단계, 이미지 2/3 Apple Cinema Display M8149 LCD Screen Replacement: 2 단계, 이미지 3/3
    • Remove the eighteen (5.25 x 4.43 mm) screws around the edge of the backplate using the Hex key.
    • Disconnect the small white connector leading to the display's Power button.
    • Gently lift the backplate off of the display. Completely remove the backplate and set it aside.
  3. Apple Cinema Display M8149 LCD Screen Replacement: 3 단계, 이미지 1/2 Apple Cinema Display M8149 LCD Screen Replacement: 3 단계, 이미지 2/2
    • Use a Phillips #2 screwdriver to remove the four (9.52 x 3.43 mm) screws on the outer rim of the metal cover.
    • Next, remove the four cover (11.91 x 2.89 mm) screws located at the corners of the metal cover using the Phillips #2 screwdriver.
  4. Apple Cinema Display M8149 LCD Screen Replacement: 4 단계, 이미지 1/3 Apple Cinema Display M8149 LCD Screen Replacement: 4 단계, 이미지 2/3 Apple Cinema Display M8149 LCD Screen Replacement: 4 단계, 이미지 3/3
    • Unplug the large brown plug in the center-right, that connects the control board to the rest of the display.
    • Unplug the blue and gray plug on the right side of the control board. Repeat with the left side.
  5. Apple Cinema Display M8149 LCD Screen Replacement: 5 단계, 이미지 1/2 Apple Cinema Display M8149 LCD Screen Replacement: 5 단계, 이미지 2/2
    • Gently lift the large metal cover which spans across the back of the whole display.
  6. Apple Cinema Display M8149 LCD Screen Replacement, LCD Control Board: 6 단계, 이미지 1/3 Apple Cinema Display M8149 LCD Screen Replacement, LCD Control Board: 6 단계, 이미지 2/3 Apple Cinema Display M8149 LCD Screen Replacement, LCD Control Board: 6 단계, 이미지 3/3
    • Carefully remove the two tape plugs on either side of the control board using a spudger.
  7. Apple Cinema Display M8149 LCD Screen Replacement: 7 단계, 이미지 1/3 Apple Cinema Display M8149 LCD Screen Replacement: 7 단계, 이미지 2/3 Apple Cinema Display M8149 LCD Screen Replacement: 7 단계, 이미지 3/3
    • Pull the previously removed tape out from the metal box with your hand.
    • Peel back the white plastic cover located on the tape plug and unplug the tape plug on the right side of the unit using the spudger.
  8. Apple Cinema Display M8149 LCD Screen Replacement: 8 단계, 이미지 1/3 Apple Cinema Display M8149 LCD Screen Replacement: 8 단계, 이미지 2/3 Apple Cinema Display M8149 LCD Screen Replacement: 8 단계, 이미지 3/3
    • Unscrew the four screws (4.79x2.33mm) on the metal box using the Phillips #2 screwdriver.
    • Lift the metal cover off to reveal a circuit board.
    • Remove the two terminal screws (4.79x2.34mm) using the Phillips #2 screwdriver.
  9. Apple Cinema Display M8149 LCD Screen Replacement: 9 단계, 이미지 1/2 Apple Cinema Display M8149 LCD Screen Replacement: 9 단계, 이미지 2/2
    • Remove the terminal cover.
    • Remove the circuit board from the right side of the unit by gently lifting it out.
  10. Apple Cinema Display M8149 LCD Screen Replacement, Voltage Inverter: 10 단계, 이미지 1/3 Apple Cinema Display M8149 LCD Screen Replacement, Voltage Inverter: 10 단계, 이미지 2/3 Apple Cinema Display M8149 LCD Screen Replacement, Voltage Inverter: 10 단계, 이미지 3/3
    • Turn your attention to the left side of the cinema display.
    • Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board.
    • Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
    • Remove the circuit board by gently lifting it from the display.
  11. Apple Cinema Display M8149 LCD Screen Replacement, LCD Screen: 11 단계, 이미지 1/3 Apple Cinema Display M8149 LCD Screen Replacement, LCD Screen: 11 단계, 이미지 2/3 Apple Cinema Display M8149 LCD Screen Replacement, LCD Screen: 11 단계, 이미지 3/3
    • Lift the screen from the surrounding front cover by sliding your fingers between the two pieces and lifting.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Curtis Musashi
회원 가입일: 04/01/11
152 평판
안내서 1개 작성함
Cal Poly, Team 10-41, Forte Spring 2011 Cal Poly, Team 10-41, Forte Spring 2011 회원
CPSU-FORTE-S11S10G41
5 회원들
안내서 12개 작성하였습니다
2 댓글
hello! where can i buy lcd screen for m8149?
jgill1971 - 답글
Does anyone know where to get an inexpensive LCD replacement. Mine went primarily magneta except for the outer edges after zapping the pram?! Totally bummed as I bought a DVI to ADC power source and now the monitor is useless in it’s current state. C’est la vie!
le_grand - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 45
전체 시간: 7,985
